what should be my fuel pressure?
Old Jun 6, 2007 | 09:39 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i installed a crane adjustable fuel pressure regulator.
i got 45 psi with ignitin on
and only 40 psi at idle
i can adjust the screw but i dont wana go too far.
so what is a safe fuel pressure but still getting some good use out of the adjustable regulator?
Old Jun 6, 2007 | 10:49 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: what should be my fuel pressure?
It depends on your engine. If you're stock, anywhere from 42-45 is good. Any higher and you could be running too rich.
Old Jun 7, 2007 | 12:37 AM
Bobby_80s's Avatar
Axle/Gears: no idea
pretty much a stock 305 v8 tpi fuel injected engine, 1986 trans am
new:
water pump
battery
radiator
egr/solenoid
iac
throttle body
throttle body coolent bypass kit
new ford 19lb injectors
new fuel pressure diaphram
crane fuel pressure regulator
new 02 sensor
k@n filter cold induction kit
new exhuast stock pipes from y-pipe to tips including new cat
new valve cover gaskets
etc....
most doesnt matter but with the new air filter kit and ford injectors
do you still think 42-45?
and is it normal for it to be less at idle then with just ignition on?
Old Jun 7, 2007 | 07:29 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I'm not sure if Ford injectors require a different pressure but usually i would shoot for 42-43.
Yes it's normal for the pressure to be lower at idle.
Old Jun 7, 2007 | 01:45 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thanks for the help
Old Jun 7, 2007 | 01:52 PM
I'd be looking for numbers like 36-37 at idle, and 43-45 at idle with the vacuum line disconnected.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
