backside of the camaro
Old Jun 7, 2007 | 08:19 PM
B&WIROC's Avatar
i destoried my rear differential (shattered the housing inside) in my 86 iroc z. i don't have the money to rebuild it so i just went to a junk yard and after searching forever i found a differential that was disk brakes and positive traction. it came off a 83 firebird so i'm pretty sure it'll bolt up. but to double check... do any of you know for sure if this is gonna work? respond quickly please!
Old Jun 7, 2007 | 08:40 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: backside of the camaro
From the little bit of info you've provided, I'd guess that it would likely work, the two things that come immediately to mind are:
1) You'll want to drive carefully for the first several miles until you can determine that the F/R proportioning on the brakes is roughly the same (or at least within a fairly safe range); and
2) The rear gears may be different, so your speedo may be off.
Good luck!
Old Jun 8, 2007 | 01:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The '83 has SAE brake lines, and '86 has metric. Otherwise, it will bolt up.
Does your '86 have disk in the rear?
Old Jun 8, 2007 | 05:21 PM
B&WIROC's Avatar
it had disk and i think i'm able to just bolt up all my brake lines and everything from my old one to this one that i bought.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
