no start
Old Jun 7, 2007 | 09:19 PM
Nick85Iroc's Avatar
Car: 85 Iroc-z Camaro
Engine: 327 HSR
Transmission: TH350
no start
just put new edelbrock performer rpm heads, HSR, and cam in my car 85 camaro with a 327. also went to a external coil so the HSR will fit. problem is it will crank over but no start. pink wire to the coil gets teh 12 volts when it is on, new distributor and coil. checked all teh fuses and there all good and it does get fuel. one of the first times i tried to start it the tach pegged out and doesnt move and i dont think the white wire is shorted on anything... what could be keepin it from starting?
Old Jun 7, 2007 | 09:34 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: no start
Is is spitting and spudering and not wanting to run or is it not doing anything and just spining over? Check your fireing order, and make shure the rotor is pointing to #1 sparkplug wire when cylinder 1 is at tdc.
Old Jun 7, 2007 | 09:42 PM
Nick85Iroc's Avatar
Engine: 327 HSR
Transmission: TH350
Re: no start
it sounds like it does want to start but doesnt, rotor is pointing at #1 when it is at TDC. could a lose ground from sumwere keep it from starting? im pretty much all out of ideas..
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
