Need injector size for 406
Old Jun 12, 2007 | 08:11 AM
SharpZ28's Avatar
Car: 92 Z28 Camaro
Engine: 350 TPI : Supercharged
Transmission: TH700R4
Most of the guys I see on the web are running ford motorsport 30lbs for 383 and 406 small blocks, and 24lbs for 350s. I have been told by a few that the ford 38lb or delphi 42s would work for me. I only want to buy once. My engine is a 400 bored .030 and is going to use the Holley stealth ram,AFR 195 heads, Comp XFI 280 cam,Scat rotating assembly with 6'' rods. Please help me with some injectors that I wont have to change for being too small once I dyno the thing for a chip burn. Thanks for any help.
Old Jun 14, 2007 | 01:56 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: Need injector size for 406
38's should be fine, although I thought 36's were the common ford size. 38's should handle 520hp at the crank. 42's if you're in the 570hp range.
Old Jun 16, 2007 | 06:06 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
30 lbs is more than enough
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
C409
Sep 23, 2015 04:30 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
