setting timming right?
Old Jun 12, 2007 | 08:33 AM
pairtoe's Avatar
ok the car is a v6 first off. but anyways what i am doing is this.
1. setting the timming mark on the balancer at 10*
2. putting the distributor so that the rotor points to #1
still wont fire, got good spark and fuel.
3. set the timming mark back to 10*
4. flip the distributor to #4 piston.
this is the way ive always done it and its always worked, but now when i do this you need to twist the distributor alot like 1/2 turn and all it does is back fire? any ideas what to do next?
Old Jun 12, 2007 | 06:25 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: setting timming right?
check that you got the wires to the right plugs
Old Jun 12, 2007 | 06:43 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Even if you want that 10deg advance you still drop the dissy in at 0deg TDC with #1 pointed at #1 cylinder. To make sure you are at TDC you can take the valve cover off and crank the motor untill you get close to 0 and watch if your #1 valves start moving if they dont its #1 tdc if not its 180 out go around to 0 again. Then you can set that 10deg.
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
TheExaminer
Aug 19, 2015 10:07 PM
