What are these springs I found? (pic)
Old Jun 14, 2007 | 05:21 PM
TRSCobra's Avatar
Car: 2018 Corvette Grand Sport Z07
Transmission: C7 Z06 TR6070
I took the valve covers off to check everything out a week after my cam swap, and I found 2 of these little springs just sitting at the rear of the left head. I thought maybe they were from my old front seal, and for some reason they stuck to the inside of valve cover when they were off. So I tightened some of the rockers, start the engine and its running a little rough.
I overtightened them!
So I remove the valve covers -again- and found FIVE more of these springs sitting in the oil at the lower part of the head.
I know the garter spring on the seal wasn't THAT big. Could they be from my oil filter?
Old Jun 14, 2007 | 05:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What are these springs I found? (pic)
They look more like shavings from something.
Old Jun 14, 2007 | 05:45 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
rod bearings?
Old Jun 14, 2007 | 05:51 PM
TRSCobra's Avatar
No, they're definately NOT shavings. Here's one of them I stretched out (sorry my camera takes lousy pics.)
Old Jun 14, 2007 | 06:25 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
look like springs out of a seal...
Possibly the front crank seal...?
Old Jun 14, 2007 | 06:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
How would they get to the top of the head?
Old Jun 14, 2007 | 06:38 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
god only knows... lol
What else uses a small spring like that...?
What kind of valve seals are in there? Maybe some sort of goofy design that uses them?
Old Jun 14, 2007 | 06:45 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
If it was me I would not start the engine again until it is figured out. I have found all kinds of metal shavings/debris in oil filters before, that`s why I blow them out good with air before I install it. Might want to pull the pan and check it and the pump. Do what`s easiest first.
Old Jun 14, 2007 | 06:48 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by TRSCobra
...a week after my cam swap, and I found 2 of these little springs just sitting at the rear of the left head.
They look like the garter springs from the valve stem seals. The .465 lift of the cam with stock rockers on stock heads should not have been a problem. You aren't running 1.6's are you? You might want to check the retainer to valve seal clearance.
Old Jun 14, 2007 | 09:25 PM
TRSCobra's Avatar
I bet thats what they are!
I changed the filter anyways. It doesn't seem to be burning any oil, so I'm gonna drive it. Takin it to the track tomorrow, lets see if I can blow it up!
Old Jun 14, 2007 | 10:20 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
I was thinking that they looked like a continuous shaving from a fine drill.
Your engine is drilling itself apart! lol
customblackbird
Aug 15, 2021 10:16 PM
aaron7
Aug 17, 2016 06:02 PM
gta90
Sep 15, 2015 04:00 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
