choppy idle
Car: 87 Camaro IROC
choppy idle
so i got this choppy idle, it normally wouldnt be a problem except now its throwing off my lockup on highway speeds. i cant pull codes cuz the light is burnt out, but i can tell you my TPS is good and my o2 sensor is reading correctly and my MAF sensor is fine as well. so without any more info, can somebody maybe throw an idea into the pot? and EGR valve issue? electronics? i need an idea.
1987 305 TPI
plz help
Gramps
1987 305 TPI
plz help
Gramps
Re: choppy idle
Iunno.... just a thought.... forgive me for being an imbecile.... I just like to have the tools to see what I'm doing and not be stabbing at ghosts in the dark
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
Re: choppy idle
Check the MAP or VAC voltages....5v in for reference and output to the computer should be ....say 1.5-4.5v depending on the pressure or vacuum. I had a problem with the TCC after a cam change and had vac issues.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: choppy idle
You do anything to the car lately?
I'd guess a plug wire is loose or broken.
Car: 1989 Camaro Iroc-Z
Engine: 5.0
Axle/Gears: stock
Re: choppy idle
i had the same problem and recently replaced my EGR valve on a tuned port motor. not only did it bring my noX levels down for emissions but it also cured choppy idle, bucking when stopping and almost dying while braking
