help please daily driver broken..literally
hello guys.
today i was driving home from a doctors appointment. and all of a sudden i heard a loud crack. i thought i had hit something. so i proceed to get out and check and this is what i saw...
im not sure exactly what is broke. any input is greatly appreciated. im a college student and this is my daily driver to work. thansk for any help
its a v6 with manual transmission. (if that helps)
it is the part inside the yellow box. it literally broke off.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: help please daily driver broken..literally
I've never worked on a V6, but that looks like the power steering bracket that broke. You'll need another one off a V6.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
trust me you dont need ot yellow box it
it is obvious as hell what happened lol
well thats crazy
what kind of cheap pos bracket is that that it cant even keep from breaking under belt tension ?
wow...
is this a common issue on these later 2.8L engines?
bad deal...
but anyways its an easy fix once a replacement bracket is located
unbolt the broken one from the pump and engine and bolt the new one on and put the belt back on
will need a p/s pulley puller tool kit(free rental at auto zone) to pull the pump pulley off to get to the bracket mounting bolts under it- if theres no room to remove them without removing the pulley since theres no access holes in it
good luck
well thats crazy
wow...
bad deal...
good luck
Hmmmm.... so THAT'S what a 6-cyl motor looks like.....
Yup, my unfailing "sixth sense" says a trip to the junkyard appears to be in your immediate future.
You might have better luck looking for that on a S truck, if you can't find a Camaro or Firebird; AFAIK since they use the same kind of motor, they might also have the same style of bracket.
So I put the bracket on and its fixed.
Does anyone know the bolt size that goes in the lower front slot of the backet? Its missing one. And I wanted get one from house of camaro. But I'm unsure of lenght . Any help would be great. Thanks fellas.
Transmission: 4L80E/4L80E
Missing bolt pretty well explains the breakage.
Can't help you with the size. Where did you get the bracket? I'd think they'd have the bolt, assuming it was a used JY bracket.
ramicio
Sep 28, 2015 01:18 PM
david068513
Sep 18, 2015 10:36 AM
