valve clearance
Old Jun 20, 2007 | 08:40 PM
transam360's Avatar
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
valve clearance
ok i just put a new cam in and new springs the cam is a 510 intake and 533 ex and my spring clearence is .040 and my seal to retainer clearence is .040 will this work or will i have to do some head work and take the heads back off or will this be good.
Thanks Eric
Old Jun 20, 2007 | 10:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: valve clearence
Spring clearance - you mean until the spring goes solid?
That's just on the edge of ok. That's on exhaust I assume, the least amount of clearance is .040"? Usually .050-.060 is the norm safe limit, but I think you'll be ok, .040" is pretty close.
Old Jun 21, 2007 | 02:07 AM
transam360's Avatar
Re: valve clearence
yes that is the exhaust the intake is .060 that should be good for that it is the exhaust i was worring about
New2Chevy
Sep 28, 2015 12:35 AM
Formula8r89
Sep 22, 2015 04:24 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
