Are LG4's 2 or 4 bolt main?
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Are LG4's 2 or 4 bolt main? I have an 86 Iroc with an LG4 and i was told not to do anything to it if it was a two bolt.
Transmission: 4L80E/4L80E
2.
Reports are some truck/van 305's were 4-bolt main.
The reason not to do anything to the LG4 shortblock has nothing to do with 2- or 4-bolt mains.
You can do a lot without touching the shortblock. Check out the 305 thread on the FAQ forum.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Are LG4's 2 or 4 bolt main?
305...78-79...2 or 4, some Canadian assembled heavy duty truck blocks have 4-bolt. main caps ...
http://64.233.167.104/search?q=cache...nk&cd=30&gl=us
http://www.hotrodsforsale.com/hrfs/t...lock_chevy.htm
no light duty 305 were 4 bolt
light duty = 1 ton and under trucks, and all cars
no vans or pickups will have this in it, no matter where it was built or sold
and all LG4 are 2 bolt
LG4 was not a heavy duty engine lol
Car: 1983 G20 Chevy
Transmission: 4L60
A stock LG4 block is 2 bolt main caps.
That is FALSE. My 1983 G20 fullsize van with the canadian cast LE9 305 was 4-bolt main from GM. I still have the block to prove it.
Mortec has my block listed as a 2-bolt main and refuses to change that listing, despite the multiple examples I have found and are out there.
14010203...305...80-85...2
I have two of these blocks, the stock one from my 1983 G20 with the UCK suffix code and one from a 1981 G20 van with the UAW suffix code, both are 4-bolt mains
I brought this to Ed at Mortec's attention and recieved this in reply. I replied with pictures of said blocks and nothing was changed. A subsequent email basically told me to **** off. They already changed the description of the 14022601 casting heads for myself and other members of the Chevytalk.com forum. Several of us had CC'd them and had another member get his engine black flagged on a 305 sprint because of their 53cc chambers. Mortec had them listed as 58cc chambers and the other member was called out as a "cheater" because he supposidly milled the heads (they are stock at 53cc mind you).
Thanks for the info. We have noted other Canadian made 305 blocks with 4-bolt caps. They are rare. Can you send photos via email of yours, showing the casting number and caps? Thanks for helping us keep the website the most authoritative casting number site for Chevys on the Web.
Ed / MorTec
email1@mortec.com
Ed / MorTec
email1@mortec.com
Engine: 4.3L Z TBI
hmm interesting
i know some exist probably but i just wont totally believe it until i saw it myself
no offense
especially with the 203 casting :P
no offense
Car: 1983 G20 Chevy
Transmission: 4L60
1989 model G20 Van with the factory tow package and a TH400. It is a 9.5" GM corporate 14 bolt that has 5 lug axle hubs like the chevrolet 454 SS trucks though. It was ordered with the factory tow package, G80 rear with the HE3 RPO for gears. I have verified the gear ratio is in the 3.07-3.08 range due to a cruise rpm of 1,500 rpm at 60 mph with 28.6" tall tires (P295/50/R17s).
Car: Iroc
Engine: 350 4-bolt
so i guess that my 86 iroc has a 2 bolt main.... will how much torque/hp will a two bolt hold?
More than the rods.
If you make enough power/torque to break a 2-bolt 305, you're making something nearly impossible to drive on the street.
If you're thinking S/C, then you need better rods right off the top. Then you can get aftermarket splayed 4-bolt main caps (same thing as a 350).
4-bolt mains from the factory were to keep the caps from walking. It had nothing to do with strength (especially since the way the factory did it weakened the block web).
Engine: 4.3L Z TBI
id like ot add/point out just for an example that the '73-80 400 sb were all 2 bolt and they seem to hold up, and actually they are more desirable than the 70-72 ones
probably because the extra bolts meant extra holes which meant less metal/material
i agree with the above about it not having to do with strength so much
good luck
good luck
Car: Iroc
Engine: 350 4-bolt
ok thanks. I just needed to prove to someone that I could still give an LG4 some ***** without thrashing it.
Car: 1984 Camaro Z28 T-tops
You said the factory used 4 bolt mains to prevent cap walk. I've heard this many times, what exactly is cap walk?
Car: Iroc
Engine: 350 4-bolt
five7kid, you said the rods where weaker than the 2 bolt main. How much hp/ftlb can a stock 305 handle?
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
