Car will not start
Old Jun 22, 2007 | 02:57 PM
19redbird89's Avatar
Car: 1989 Pontiac Trans Am GTA
Axle/Gears: 3.23 9 bolt
Car will not start
Key in the ignition, turn forward, feul pump comes on and the lights on the dash board come on as usual, then nothing, no click or anything at all. Right before this it would do the same thing but after a couple turns it would start up now nothing at all. any ideas.
Brandon
Old Jun 22, 2007 | 04:02 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: Car will not start
sounds like an electrical connection. I would check all wireing associated. You ever try tapping the starter with a hammer when it does this >?
Old Jun 26, 2007 | 10:36 PM
I jumped it off and it started but after i ran it for a bit and then put it away, i tried to start and it gave me a turn over on the first try and then second nothing. on the third it started right up. my connections all felt good but i am starting to think that maybe my alternator is not holding a charge very well. hopefully it wont be hard to figure out
Old Jun 26, 2007 | 10:44 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
alts dont hold a charge batteries do have you actually checked the park/neutral saftey switch or just made sure it was plugged in? mine does that once and a while granted mine is a T5 not an auto so my saftey switch sees alot of action with the clutch but they do wear out
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
L98GTA87
Aug 5, 2015 11:02 PM
