exhaust manifold sound
Old Jun 24, 2007 | 05:23 PM
kora18's Avatar
Hello my 1989 camaro rs exhaust manifold makes a weird sound like if it was ripped or something it seems like if air was comin out of the exhaust manifold but i dont know someone told me that i could fix that by tighting the exhaust manifold bolts but i dont know how to do that or wat bolts to tighten so if any oneknows what it can be can u please tell me thanks
Old Jun 24, 2007 | 06:03 PM
Chris`s85Z28's Avatar
Car: 1985 Z28
Engine: LG4 305 with a few modds
Re: exhaust manifold sound
well you either blew a manifold gasket or cracked the manifold... you can try tightening the manifold bolts theres 6 of them along the side of the manifold... easy way to check though is to take soapy water with lots of bubbles and pour it over the manifold when it`s running but still cold, you should see bubbles where the leak is.
Old Jun 26, 2007 | 06:49 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
should be pretty obvious if theres a leak
will be black carbon
if not then try a hollow pipe and your ear, listen around
leaking exhaust can be anything from a little tick sound, to full blown leaking noise
depending on how bad it is
ive seen them all, leaking gaskets, blown out donut seal, cracked manifold, etc
good luck
AussiePr0nCar
Mar 6, 2020 04:04 PM
chazman
Aug 28, 2018 03:25 PM
transaero
Aug 31, 2015 01:14 AM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
