Help with timing please?
Old Jun 28, 2007 | 05:57 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
My car's been overheating and I have a feeling that it is atleast to some degree due to bad timing, I don't have a timing light, but If I wanted to just turn it a few degrees in a direction to see if it helps, which way should I go? Is there a decent way to time our cars without a light?
Thanks.
Old Jun 28, 2007 | 08:09 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Help with timing please?
a vacuum guage will get you really close
otherwise get a light
both are inexpensive
borrow one from a shop real quick if you have to
hell ive had timing lights given to me for free before
good luck
Old Jun 28, 2007 | 10:24 PM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
I happen to have a vacuum gauge. how can that help? highest vacuum while turning the distributor?
also, if I go out and buy a timing light, how can I make sure my timing tab is accurate? I had never thought about the possibility that it may not be until the last few days reading post after post on these boards. When I had my engine built up to a 383 I put a new harmonic balancer which I'm not sure of the brand, and a new timing tab which I'm pretty sure was Mr.Gasket, got it from congress auto parts.
also, last time I had a timing light on the car I remember the timing was jumping around an awful lot, I'm not sure if the guy doing it had the distributor disconnected or what, but if anyone's seen this before and knows why it happens I'd like to know what to do to fix it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
