Identifying heads without disassembly?
Car: 20 M550i xDrive
Engine: LB9 305 TPI
I recently finished my project here and I was curious how to identify my heads without tearing anything apart as it is a running car.
What I know about the heads is they came off a 1984 corvette 350 w/ cross-fire injection (2 bolt main, if this helps at all?) and the intake valve size is 1.94. I'm curious because I'm wondering what kind of power these things can push. Thanks.
Transmission: 4L80E/4L80E
You can get the casting #'s by pulling the valve cover. I wouldn't call that "disassembly". That will at least tell you what they were from the factory.
92projectcamaro
Jan 18, 2016 08:00 AM
