Mini Starter...whats the advantage?
Old Jun 30, 2007 | 10:43 AM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I know they are obviously smaller and lighter but what are the advantages? I just bought one from Summit and I know they work with both 153 and 168 tooth flywheels which is good and I heard they are more torquey?
Old Jun 30, 2007 | 11:32 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Mini Starter...whats the advantage?
They fit into a tight area especially if you have large tube headers.
They're much lighter which cuts a lot of weight off the car.
They're normally more powerful. They can produce more HP to crank over a high compression engine easier.
Not all mini starters are made the same. Many use cheap parts in them and won't last as long as a factory style large starter.
Read this post
http://www.calgarydragracing.ab.ca/p...opic.php?t=259
djmarch
Oct 2, 2015 10:41 PM
75bike
Sep 20, 2015 09:37 PM
Magman
Sep 13, 2015 12:07 AM
09ave
Sep 7, 2015 06:03 PM
