Mechanical fuel pump question
Old Jul 1, 2007 | 02:43 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
For those of you who have switched to an old school mechanical pump for your carb, what did you do with the wires that ran to the electric pump? I'm not sure if I should cut them or just tape them up to the top of the sending unit and call it good. I thought I read a post where you have to hook up a ground wire, but I can't find it in the forums. Maybe I'm way off on this, but it seems like I should be able to just completely remove those 2 wires and leave the sending unit wire intact. Any suggestions would be great.
Old Jul 1, 2007 | 03:04 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Mechanical fuel pump question
You'll need to pull the tank and replace the in tank electric pump with a simple carb style pickup.
The pump won't pull through an electric pump - for long.
Old Jul 1, 2007 | 03:15 AM
elky74's Avatar
Yeah, I already dropped the tank, but was planning to modify the sending unit to work for a carb application. Seems like a lot of people do this, so I just wanted to know what they do with the electric fuel pump wires for this mod.
Old Jul 1, 2007 | 12:03 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i always just put a piece of 3/8" fuel hose in place of the pump and put the sender back in
no need for a carb sender, no real difference other than the addition of pump wires
works fine
good luck
Old Jul 1, 2007 | 12:40 PM
elky74's Avatar
My original pump was TBI, which I have eliminated already. My question is, what to do with the leftover wires that controlled that pump since I won't need them for the mechanical pump. The wires will just be hanging there inside the tank if I leave them on the sender. I realize they are not needed for the sending unit, but I wanted to see what other people did with the wires.
Old Jul 1, 2007 | 05:55 PM
elky74's Avatar
bump
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
