timing cover gasket
Old Jul 1, 2007 | 05:32 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
timing cover gasket
Is it possible to unbolt the oil pan with the motor IN the car or slightly raised? I need to insert the lower timing cover gasket and to do so, I need to remove the oil pan. Anyone ever done this?
Old Jul 1, 2007 | 07:36 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: timing cover gasket
Yeah just raise the engine take out all the front sump screws and undo the rear ones half way and it will drop far enough to insert the new seal.
If you don't have a 1/4" socket with uini joint (with spring) get one it coz makes the job alot more easy.
Old Jul 1, 2007 | 09:11 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
no you dont need to lower the pan to remove the timing cover
jut take out the front pan bolts and the timign cover will come off
after you get it off snip the corner ends of the metal lip that the lower seal sits in so it will go back on easier
RTV the corners real good
easy as cake
this is how to do them
no need to drop the pan and go through all that PITA
getting the cover off the two locating pins is the hardest part
Old Jul 2, 2007 | 04:59 PM
Engine: 400
Yeah we didn't seal it good enough and put the motor in and now it leaks. Thanks guys.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
MY87LT
Aug 17, 2015 08:43 AM
86White_T/A305
Aug 17, 2015 12:16 AM
