1pc rear main seal install
Old Jul 5, 2007 | 12:44 PM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey Ya'll, I've got a Fel-pro 1pc rear main seal to install and on the "flat"
side of the seal there is the word "outside". Does this mean I should install
the seal with "outside" in the housing toward the tranny or in the housing
toward the block ? I know this question sounds dumb but if there's a way
of screwin' up - I'll find it !
Old Jul 5, 2007 | 04:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 1pc rear main seal install
Originally Posted by T-rick'srod
... in the housing toward the tranny ...
That way.
Old Jul 7, 2007 | 12:19 PM
Car: '88gta
Engine: 383 tpi
Thanks five7kid !
Old Oct 3, 2008 | 08:42 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
No point starting another thread so here's my question... I've already got the old seal out using a small prybar. Do you need a specialty tool to install the new one? The service manual says so, but then again they suggest a specialty tool for just about everything. Any tips so I don't screw up the seal? Was just planing on coating it real good with oil and work it around a bit at a time. Does it bottom out or do you just stop when it's flush with the retainer?
TIA
Old Oct 3, 2008 | 09:02 PM
five7kid's Avatar
Keep it as square as possible as you drive it in. Small hammer taps walking around the seal usually work best.
The tool just contacts the entire seal frame at the same time with a stem in the center to hammer on.
Old Oct 4, 2008 | 06:29 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
My "special" tool is a 2x4 against the seal and a hammer to hit the 2x4.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
Exxon Limited
Aug 9, 2015 08:13 PM
