Harmonic Balancer question.......
Old Jul 6, 2007 | 03:33 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Is there a difference between a 6 3/4" and 8" balancer, besides the obvious 1 1/4"?
Old Jul 7, 2007 | 11:43 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Harmonic Balancer question.......
I guess you could have some clearance issues, depending on what front accessory drive you are running...
I think the big deal is how it is balanced. The smaller ones tend to be for internal balanced engines and the larger ones tend to be for external balanced (like 400 engines or engines using a 400 crank) applications, although this is not always the case.
Some of them line up better with certain timing pointers if they are the appropriate size, as well.
Old Jul 7, 2007 | 05:34 PM
Most 350s from about 69 to about 77 had the 8" damper, and they're neutral balance.
Other than the internal/external balance thing, the most likely problem you'll have is getting the timing mark right. If you still have your stock 3rd gen timing mark, the bigger balancer won't even go on, because it will hit that.
They're all the same thickness, even the ones that came on 265s and 283s that's nothing but a pulley flange.
Old Jul 7, 2007 | 08:02 PM
Damon's Avatar
I notice in your sig you are using the 142 blower, same as me. Go with the bigger balancer for sure with the blower.
I also agree with what's posted above- the timing marks on a smaller 6-3/4" balancer can be in one of two places.... either at the common 1:30 position sticking out near the driver's side leg of the water pump or at the 12:00 position straight up behind the water pump. 8" balancers only come in one timing location variety.... the 1:30 position. The position of that line on the balancer and the location of your timing tab must match to show accurate timing when you are shooting it with your timing gun. So with the 8" unit there's less likelyhood of a mismatch between the two.
Either size will clear the stock accessories/pulleys/brackets, etc. on a 3rd gen F-body.
Old Jul 7, 2007 | 10:15 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by Damon
... 8" balancers only come in one timing location variety.... the 1:30 position...
8" can be either 12:00 or 1:30 o'clock. See pic.
Old Jul 8, 2007 | 12:19 PM
Rocket-Doc's Avatar
Thanks for the answers guys..
Old Jul 8, 2007 | 01:50 PM
BadBlueRoc's Avatar
I just to replace my 8" balancer on my 3rd gen I'm not sure the guy that built it should of even put it on... The 6 3/4 one I pulled off an 305 87 van which my 350 motor is from 91 camaro is 1/2 thinner then the 8" one but everything timed up alright. Has anyone ever heard when a Harmonic Balancer goes bad? Your gut drops when hear it let me tell you. I was happy to see when I pulled the main pulley off it and all the bolts were oblonged. I've got pics if anyone is interested. So I got a new pulley and went to the junk yard and got a new balancer and was surprised to see it smaller and thinner.
Old Jul 9, 2007 | 09:15 AM
Damon's Avatar
Supervisor: My bad. I never ran into that before. Could you tell me what the factory application was for that?
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
