Cooling system pressure testing
Old Jul 7, 2007 | 04:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Hey, I bought an OTC 7991 cooling system pressure tester here. Set it into the rad, inflated the bladder and whatnot. Should be a good seal there.
It would hold 15psi in the rad ok, I think it might have been bleeding down very slowly.
I then removed the t-stat, and re-RTV'ed the waterneck back on. Now I pressurized the system (and found a slow leak from the heater core, so I tightened up a hose clamp and i'm good). Anyway, it's still leaking down pressure, but very slowly. It takes 10 seconds to bleed down from 15psi to 14psi. Is this a normal result, or do I have a leak?
Reason I ask is that I'm getting coolant into the oil, and I can't figure out why. I've replaced head and intake gaskets, and it's the same thing - fire it up, 10 seconds later i've got chocolate milk oil.
I figured it was from spilling some coolant, since I don't think it takes much to make the oil milky, but since it happened twice (before and after replacing head and intake gaskets), i'm a little leery on that.
I'm thinking cracked head or block now. However, with the speed this bleeds down, I can't hear any hissing at all. None. I'm using a stethoscope and everything.
Any ideas?
Old Jul 7, 2007 | 05:07 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Re: Cooling system pressure testing
Have you tried sending an oil sample to wix?
Old Jul 7, 2007 | 05:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
What?
Old Jul 7, 2007 | 07:13 PM
Wix sells a deal for sampling oil, looks like a little film bottle, you fill it up with your used motor oil and then send it prepaid (in usa) to them. They fill you in as to how much Hydrocarbons, antifreeze, and other trash is in the oil. Here in the usa it runs around $18. I wish i could remember the part number, but its been about 6 months since i was in the parts business. Probably have to call wix to get the part number.
Old Jul 7, 2007 | 07:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's a leak. You should be able to pump it up and leave it for 20 minutes or so without losing any pressure.
Old Jul 7, 2007 | 08:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, unfortunately knowing how much antifreeze is in my oil, still doesn't fix my leak though
Hmm, i'm not sure if it's the bladder sealing part that's leaking, or something in the engine. Although i'm fairly sure I have a leak in the block ( due to the oil in the coolant ), i'm still no closer to knowing WHERE. *&^(*%^%
Old Jul 7, 2007 | 08:11 PM
yeah but itll give you and idea how much, and if gets in while its sitting or running
Old Jul 7, 2007 | 09:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you think the block is leaking, you might as well pull it and take it apart. If you can't see a crack when you do, you can take it in and get it tanked. It'll be cheaper than magnafluxing and if you're lucky, a crack will show up as a soda line after it comes out of the tank.
Old Jul 7, 2007 | 10:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Well that's a colossal hassle. I'm fairly certain it's not the head or intake gaskets. I'm pretty sure the block deck is flat, as it was decked when I built the engine, and I checked it with a straight edge before I put the heads on this time. But that's all I really know. Cracked block, ie. requiring me to completely pull it and tear it apart, is really not a weekend easy job for me.
Is there anyway I can narrow it down *before* I tear it apart?
Old Jul 8, 2007 | 03:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
Bars stop leak time. Lets see how this works.
I'm going to put it in with the t-stat out, let it run as long as I dare, while keeping the dipstick out. If it overflows out the dipstick, it's leaking too fast. But if the oil level stays constant, then it must be working.
Then i'll change out the oil again (geez, i'm single handedly employing a refinery...)
Lets see if this works now...
Old Jul 8, 2007 | 05:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Don't bother with the dipstick thing. If the level gets that high you've got bigger problems from the crank smacking into the oil.
Old Jul 8, 2007 | 07:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
That may have solved it. I added stop leak, changed oil and filter (watery oil), added new witches-brew of oil, ran it. Setting lash hot is hard, I have no sense for that. Anyway, the oil seemed to stay clean, so we'll see on that one.
I've still got to add the t-stat again, then i'll see if it holds together.
92camaroJoe
Jul 29, 2023 07:57 PM
TheExaminer
Aug 26, 2015 04:59 PM
sreZ28
Aug 14, 2015 07:48 PM
92camaroJoe
Aug 13, 2015 06:07 AM
