Engine revs up
Old Jul 8, 2007 | 10:30 AM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Engine revs up
My engine revs up on its own while she is at idle and when u drive, anyone have any ideas as of why?
Old Jul 8, 2007 | 11:48 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Engine revs up
intermittent vacuum leak?
MAF sensor?
AIC sensor?
Any codes?
Old Jul 9, 2007 | 12:11 PM
Engine: V8 305
Re: Engine revs up
No codes as of yet, but I am not sure that it works bc I got to rewire the car. What is an AIC sensor?
Old Jul 9, 2007 | 01:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Engine revs up
Idle Air Control.
There's probably a way you can test these sensors with a multimeter, since the ECM may or may not be helping you out. Check your haynes manual perhaps.
Old Jul 9, 2007 | 01:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by Sonix
AIC sensor?
Now, which is it: Air Idle Control, or Idle Air control???
Old Jul 9, 2007 | 05:02 PM
RodsRideSS's Avatar
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
Re: Engine revs up
Check your EGR type...if it runs off exhaust backpressure..it could be a problem with the cat or the EGR itself.
Infested
May 22, 2018 11:56 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
db057
Aug 22, 2015 08:17 PM
perZ
Aug 21, 2015 05:51 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
