Code 33?
Old Jul 8, 2007 | 06:28 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Code 33?
Well
Old Jul 8, 2007 | 06:34 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Code 33?
Well I have a 92 TA TPI. Month back I built a 355 for this car and installed it with the XFI268 Cam. Had a bunch of problems and ended up getting a Ostrich to try to tune the computer. I finally had it driveable but some bugs to work out still. I noticed some oil leaking from around the heads and figured they needed to be re-torqued. So I torqued the heads down put everything back together and now it won't run for crap. The idle flucuates a little and the ses light comes on and turns off. So I finally got a steady code. Code 33. In the book this is the map sensor. So I hooked up the laptop and noticed the volts for the sensor were lower then normal. Last time it was running good they were above 2.?? now there 1.5v. I checked all the wiring everything looks good. Does this sound like a bad map sensor? Is there a way of testing it? Thanks for the help.
Old Jul 8, 2007 | 06:38 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: Code 33?
Mass Air Flow
Old Jul 8, 2007 | 09:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's a '92, which is SD, not MAF.
So, MAP sensor.
Old Jul 9, 2007 | 09:23 AM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Re: Code 33?
Anyway, I'm wondering if I have the valves adjusted too tight. It did some backfiring and everything seems to be building up alot of heat, more than usual. So I'll try readjusting those today and see what happens. Any other ideas?
Old Jul 9, 2007 | 05:39 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Re: Code 33?
So, MAP sensor.
Yeah, not sure how I missed the year, Hrmm.
Old Jul 9, 2007 | 10:03 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Re: Code 33?
Well adjusted the valves again seems to have helped, but now it looks like I fryed another ignition control module. The car cuts out and the tach bounces around. So I just ordered a Hi Perf dist since this one is the original. Since the pick up coil is probably bad too. Hopefully that will solve my problems.
Old Jul 9, 2007 | 10:40 PM
five7kid's Avatar
Exactly what distributor did you order?
Old Jul 9, 2007 | 11:23 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Re: Code 33?
HEI made by Pertronix, for TPI motors
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
