CONNECTING ROD ??
Old Jul 9, 2007 | 01:39 PM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
CONNECTING ROD ??
after i had my rods separated from my pistons i noticed that one side was tapered at the top.iwas wondering witch side(inside, outside) of the motor is it supposed to face?
Old Jul 10, 2007 | 05:50 AM
Damon's Avatar
Re: CONNECTING ROD ??
On the inside where the bearing shells rest against you will find 2 notches- on on the rod, one on the bearing cap. Those notches both need to be on the same side when you assemble the rod (not opposite eachother) AND point towards the oil pan rail of whatever cylinder bank you have that rod installed on. Left side pistons/rods the tabs point towards the left side pan rail, right side pistons/rods the tabs point towards the right side pan rail.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
Street Lethal
Sep 7, 2015 01:09 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
