help this camaro!!!plz
Old Jul 12, 2007 | 02:50 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
aight i made a video didnt wont to run it long.it flooding its as* off replace all the sensor on the intake also replace burn/off relay.
Old Jul 12, 2007 | 05:16 PM
alpine247's Avatar
Car: 1988 IROC-Z
Re: help this camaro!!!plz
i know what it is now.
well my dad said it might be the ecm mess up,i had a v6 ecm so i put it in,idles good but dies when i give it gas.so get a new ecm it be running good
Old Jul 12, 2007 | 07:41 PM
alpine247's Avatar
Car: 1988 IROC-Z
well i thought about it,it is a V6 ecm.so would that be my problem still,it idles fine but running rich.plug the wires back in to my ecm crank it up starts to flood it again.
Old Jul 12, 2007 | 08:33 PM
alpine247's Avatar
Car: 1988 IROC-Z
also since i replace the burn/off relay the light stays off.but it still have a rough idle and getting to much gas.
Old Jul 12, 2007 | 08:49 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
okay you know you are getting too much gas... what kind of fuel preassure do you have? how about after you turn off the key? how long does it take to bleed down?
Old Jul 12, 2007 | 09:20 PM
alpine247's Avatar
Car: 1988 IROC-Z
dont have a way to test the fuel pressure, well kinda dont know how yet.still learning
Old Jul 12, 2007 | 09:56 PM
alpine247's Avatar
Car: 1988 IROC-Z
well i know how to now kinda easy lol.but i dont have a fuel pressure tester.
Old Jul 12, 2007 | 10:10 PM
Car: 91 RS
Engine: 350 vortec
i thin autozone might rent them or you could always purchase one
Old Jul 12, 2007 | 10:11 PM
alpine247's Avatar
Car: 1988 IROC-Z
so it wouldn't be the ecm? or would it
Old Jul 12, 2007 | 10:16 PM
alpine247's Avatar
Car: 1988 IROC-Z
aight i check it out.what esle could it be if it the psi is normal?
Old Jul 12, 2007 | 10:19 PM
Car: 91 RS
Engine: 350 vortec
well that depends... you have a 305 TPI right... and you are running the Ecm for a 305 TPI...then no my first guess would be dirty, clogged, leaky injectors
or fuel preassure... either one can be checked by checking fuel preassure with the key turned on but engine off... you should get around 40-44 psi... and it should take a good while to bleed down after you turn the key off without starting the engine.
if you get ~44 psi but then it starts to bleed off really fast you have a leaky injector... if you get more then 48psi you have to much Fuel preassure and i would look at your regulator
Old Jul 12, 2007 | 10:28 PM
alpine247's Avatar
Car: 1988 IROC-Z
i have a 350 tpi same though,but like i said i put in a ecm that came out of 2.8 v6 and the car idle fine dont flood a bit.but when i hit the gas it seems like it starving for fuel.
well the owner replace the pressure reg,and install some mustang injectors.
Old Jul 13, 2007 | 08:31 PM
alpine247's Avatar
Car: 1988 IROC-Z
ok i bought me a tester today.
i have 42lb of fuel psi but it drop from 40 to 30 pretty quick like 15 secs.so leaky injectors?
Old Jul 13, 2007 | 09:37 PM
Car: 91 RS
Engine: 350 vortec
yes leaky injectors would be part of it... it should take a few minutes to drop off... also the ford injectors are rated differently than GM or so i hear chip modification would be necesary to totally cure the rich condition i think
Old Jul 13, 2007 | 09:45 PM
alpine247's Avatar
Car: 1988 IROC-Z
would LS1 24lb injectors be too big for my stock engine?
Old Jul 13, 2007 | 09:51 PM
Car: 91 RS
Engine: 350 vortec
if it is a stock engine why play with injectors the stock ones will work
Old Jul 13, 2007 | 10:02 PM
alpine247's Avatar
Car: 1988 IROC-Z
well the stock cost about $350 with being im only 17 with a part time job i never get this camaro up and running.i found the LS1 injectors for $160,but can u fix the leaky injectors.
Old Jul 14, 2007 | 09:21 PM
alpine247's Avatar
Car: 1988 IROC-Z
well after all it was the ecm,a person i barely know gave me a ecm and a maf sensor.so i came home and plug the ecm in,run like a top but it running alil rich but that probably them ford injector doing that.
now i have to take the oil pan off and put a set a rod bearings in it,and also going ahead replacing the oil pump.man that pan is going to be a pain lol
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
