Another timing question
Old Jul 19, 2007 | 04:49 PM
dahn's Avatar
Car: 86 camaro
Transmission: 700 auto
Axle/Gears: 308
Why does it say in the Haynes manual not to unplug the four wire EST connector it says to unplug the black and tan wire I have a 1986 305 CC carb. Will it damage anything? Is this how I set it,with the engine off disconnect the four wire EST coming off of the distributor. Start the engine time it to spec turn the engine off reconnect the EST ready to go?
Old Jul 19, 2007 | 04:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unplug the flat 4-wire connector, start the engine, set the timing. Shut off the engine, reconnect the flat 4-wire connector, clear the computer code(s), drive happily ever after.
I'm not going to even try to explain why the Haynes manual says what it says.
Old Jul 21, 2007 | 11:32 AM
dahn's Avatar
Car: 86 camaro
Axle/Gears: 308
Re: Another timing question
Thanks for the information
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
