What is the BEST coil to get with digital 6 box???
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
As the title says, what is the best coil to get for 100% street driving when running a MSD digital 6 box?
I am running a mallory HEI right now and it is leaving a lot on the table. So I want to upgrade to a small cap billet MSD dizzy, with a digital 6 box (I want it for the single stage of timing retard for N20). I have 8.5mm wires already. All I need now is what coil to get. I have checked summit but they have so many and it doesn't say what is good/bad for the street. Some say you need a 7 box, fine, then those are out of the question. But there are still too many to choose from. Please give any advice you have, thanks.
-Dennis
-Dennis
Transmission: 4L80E/4L80E
I'm using the Blaster SS 8207 with the Digital 6 box and billet distributor for the 396.
Not sure how high you're spinning it, but I have no issues with 6200 RPMs.
Engine: LS3
Re: What is the BEST coil to get with digital 6 box???
Thanks, i was looking at coils almost 3 times that much, but if that works well with the digital 6 box, then i will pick one up. thanks again
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
