surge..bad IAC or TPS?
Old Jul 25, 2007 | 12:03 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I have idle surge and in gear idle surge.....what would cause that?....I was thinking its the IAC..am I right? I have tried to set IAC the TECH way....and I think ive noticed that when I fire the car up after unpluging the IAC.....ofcourse the car idles real low.....but it does not surge at all.....would that mean the IAC is bad?
Old Jul 25, 2007 | 02:59 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: surge..bad IAC or TPS?
fuel pressure problem.
Old Jul 25, 2007 | 08:14 AM
why do you say its fuel pressure?
Old Jul 25, 2007 | 10:41 AM
FASTERTHANUMARK's Avatar
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
Next time it surges unplug the TPS.If it stops surging thats most likely your problem.Have seen this many times before on lots of cars.
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
