10-40 oil with nitrous???
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
is this a fine weight for my car with my 100 wet shot of nitrous and what spark plugs would i use too?
Re: 10-40 oil with nitrous???
The oil should be fine.
Drop a heat range or 2 cooler on the plugs, and use the non-extended-nose version; instead of R45TS, use R43T or R44T for example.
No doubt you can get them in NGK.
I have no clue whether that's a suitable # or not. You could try crossing those AC numbers.
bigjay89gta
Oct 15, 2015 08:04 AM
skinny z
Oct 5, 2015 06:23 PM
