L98 miss at low rpm
Old Jul 28, 2007 | 04:32 PM
MADMAXGTA's Avatar
Car: 89 TTA
L98 miss at low rpm
I just picked up a 89 gta(71,000 miles),and it seems to run excellent except for the fact you can feel a miss when In gear,at idle up to about 1500 rpm,then fades away.Its very faint,but its ther,you can feel it most when on the brake,any ideas before I get a diagnostic done?
Old Jul 28, 2007 | 08:09 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: L98 miss at low rpm
if ur not throwing a code then dont bother with the diagnostics bc the computer cant read it... if it did then the code would show... could be a couple of things, i would check ur plugs/wires/cap... sumtimes the coils and control modules do weird things.i would also check ur timing. if that all checks out ok then i would disconect the knock sensor and take it for a quick run to see if it stops or disconnect the ecm spark advance connector and see if it runs better.
other things to check would be TPS voltage, IAC etc
just a stupid question are u sure its a miss and not engine noise/rattle/resonace etc bc that seems to only happen at idle and low rpms
Old Jul 29, 2007 | 01:36 PM
MADMAXGTA's Avatar
Car: 89 TTA
yea,no codes.I decided to pull a plug,#8 the hardest to get to,it looks very old and the plug wires look old too,# 8 wire pulled apart when I tryed to remove it.So hopefully this is all my troubles right here. Ill replace the plugs and wires later this week and let yeah know,THX
Old Jan 21, 2008 | 10:55 PM
dboersma69's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Did your car run better after plugs and wires?
Old Jan 22, 2008 | 08:48 AM
MADMAXGTA's Avatar
Car: 89 TTA
Yeah,a little bit,those plugs were nasty black,but Ive also discovered my fuel pressure at idle is 10 pounds to low ,the miss seems to dissapear under acceleration,until you hold the rpms study then she shakes,but not much,Im guessing this is cause my fuel pressure is low.Its in storage for the winter,so I wont have a solution to post till spring....winter sucks
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
Jake_92RS
Aug 17, 2015 09:42 AM
jackhammer
Aug 15, 2015 10:04 PM
perZ
Aug 15, 2015 01:17 PM
