Oil pressure problems!!
Old Jul 31, 2007 | 09:22 AM
79frankenstein's Avatar
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
Ok i have a 79 350 in a 86 Z28 from a cold start i have 40-45 psi then when the car warms up it drops to 20-25psi. what may be the problem???
Running 10-30 oil
Torker II intake and cam
Stock heads and bottom end
Stock oil system
Edelbrock AVS Thunder 650 cfm Carb.
Old Jul 31, 2007 | 09:45 AM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Re: Oil pressure problems!!
Running 10-30 oil
Stock oil system
What oil are you using? Multi-Viscosity I hope! Put in some 10-40 so that the oil is a little thicker when its hotter. Actually, 20-25 is okay at idle, hopefully it shoots up into the 60-70s when your over 4000 RPMs though.
Old Jul 31, 2007 | 09:54 AM
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
yes it does however some one told me that oil pressure that low even at idle can do damage. The oil inst multi-viscosity but i will change over to that with a 10-40.
Old Jul 31, 2007 | 11:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't have a problem. 10 PSI per 1000 RPM is more than enough pressure.
Old Aug 1, 2007 | 01:04 PM
WhiteHawk's Avatar
Car: 1991 Firebird
I know at chrysler 2.7 V6 spec is 10 psi at idle, which is scary low. Its common on those engines to have a low pressure oil light flicker come on when the engine is worn because it drops under 5 psi at idle...bad mitsubishi oil system design...those engines blow in the 60k ALL over the place. Its a pretty HiPo engine, textbook race design, has a ton of HP per liter.
Old Aug 1, 2007 | 01:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't need 10W-40 oil. 10W-30 is fine.
One rule of thumb for these cars is before you take any action with regard to indicated oil pressure, attach a mechanical gage and see what's really happening. The sending units are notorious for going bad, and the dash gage system is more of an indication than a measurement.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
