Piston rings?
Old Aug 3, 2007 | 03:09 AM
devildust's Avatar
Engine Done?
So my car started making popping sounds like it was misfiring, during which time when i give it gas it has no power just crazy popping(misfiring). Today I pulled the plugs, they were covered in oil, one was so bad that there was no way there could have been spark. I pulled the plugs not that long ago(4 months ago, less than 2k) they were fine, now they are ****ed. Would this be possibly cause by bad piston rings, if so what are my options(how bad can it be?) . I was planing on doing some upgrading like aluminum heads, but with that and a rebuild it might just be cheaper to find a built motor. So what do u think. Thanks.
Old Aug 3, 2007 | 05:52 AM
Re: Piston rings?
Not likely to be the rings.
Sounds more like a valve train problem (rolled cam lobe, rocker nut backed off, etc.) or a head gasket blown between 2 cyls.
Old Aug 3, 2007 | 01:19 PM
devildust's Avatar
Re: Piston rings?
this is what they look like. i think it is valve guide seals.
Old Aug 3, 2007 | 04:53 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Re: Piston rings?
Sofakingdom, im not going to fight with you over this, but..... Probably not.
I'm more with the idea of bad guide,the head gasket is a veritable idea, are they AC Delco plugs or otherwise? I see they are. oopps
maybe bad rings but i doubt that too
Anyways how many bad plugs do you have, Motormite sells non foulers that may help you, be careful as they create a much hotter spot in the motor, making things alot easier to burn a piston
Old Aug 3, 2007 | 11:28 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Piston rings?
those plugs are 4 months old? maybe 4 years no way you get that much rust but those deposits what kind of a texture are they almost rock hard or soft and oily?
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
