Vortec Rocker Arm Questions
Car: 1987 IROCZ
Engine: 355, Vortec Heads, Carbed
Transmission: TH350, 2800 stall
Axle/Gears: 3.27 9 Bolt
Hello, I am finishing up the build on my engine and just curious on what rocker arms I should go with. I tried searching and couldn't find anything on this...what is the max lift for the stock rocker arms on a set of 906 vortec heads? I am running a comp cams xr276hr, .503/.510 lift. If these rockers don't work would a set from a ZZ4 work? Thanks!
Transmission: 4L80E/4L80E
The stock rockers probably don't have long enough slots for the lift of that cam.
ZZ4 aren't self aligning.
Comp Magnums are a pretty good bet. About $200/set, but good quality stuff. For another $130, you can't go wrong with Pro Magnum full rollers.
For stamped steel, check out summitracing.com, p/n NAL-12495490. Long slot, self-aligning. $55/set.
With that much cam, though, at least roller tip is good insurance.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Vortec Rocker Arm Questions
I hope you are running heads that have been machined for higher lift as well
Car: 1987 IROCZ
Car: 1984 Z28
i'm running the long slot summit brand 1.5s that are in the circle track section, work fine for me. Although this winter it'll be getting full rollers.
ambainb
Apr 25, 2016 09:21 PM
