Is Balancing 87 & up flywheel possible?
Old Aug 21, 2007 | 11:22 PM
  #51
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: Is Balancing 87 & up flywheel possible?
Talk about making things far harder than they really are. Damn.
Originally Posted by Fbody fan 35yrs
.... other 87 and newer gen I small block owners with externally balanced motors who replace their flywheels have them "balanced matched" to the flywheel they took off as they are balanced to the crank as a "matched pair"...
Technically it's against the weight that's stuck to the torsional damper, not the crank.
I'm sure in your research you did a search on this site correct? This has been covered before, but you knew that right? No, well let me pull out a volume or two out of the handy dandy den library thusly allowing me to reach into the grave and see what John himself says:
What many Chevy fans may not know is that all '86-and-later smallblocks are also externally balanced...they also require the specific one-piece rear main seal crank flywheel/flexplate. This external balance also differs from the 400 cid style since the torsional damper... is externally balanced...
Clear now? No? Ok...
See, what you are failing to realize, and the point that many have vainly tried to make, is that you are not looking at the whole damn thing. The flywheel is balanced offset to the torsional damper. Every car. Every time. You DO NOT balance these engines like the traditional externally balanced motors Like say a 400)!!!!!!! Clear enough? No? Ok...
Think on this, why is it the damn thing only bolts up properly ONE WAY? Just a fluke of production? Do you truly think that GM engineers are that inept as to not think this through in their redesign? well, that's possible...
Well I went to the Chevy dealer today looking for the elusive flywheel balancing spec that the three machine shops I called had no knowledge of. A service guy and I searched their data base for about 15 min. and the only thing we found was this quote. "replacement flywheels must be balanced to match the one being removed" That is exactly what the sticker on my Fidanza flywheel says. I may not be a smart man........... but I know what that means. If there is a "balancing spec" out there I challenge all who think there is to come up with it from a ligament source! ....
Since the company that actually produced the vehicle doesn't have one, and the tech who is paid to specialize in the repair of said vehicle had to spend 15 minutes searching for some mention of it (plainly suggesting that he was clueless about this allegation) one could come the the wholly reasonable conclusion that the spec you are looking for does not exist.
That conclusion is patently wrong on the face of course, but I would venture that you could find from a manufacturer the weight spec and radian of placement on the flywheel/flexplate.
Ok, let me set you on the path of the right question to ask...
Q: In relation to the torsional damper, what is the acceptable specification for the weight and radian placement on the flywheel in order to return the whole of the 'crank assembly' to 'neutral' when you use a new flywheel with a used torsional balancer on the other end of the assembly.
A: Who bloody really gives a rat's droppings if it's not a race motor?!? Pick one on the parts shelf that has been manufactured to within those elusive specs because quite honestly no shop really wants to mess with this nonsense minutia as it's been taken care of well before the first production engine came out for sale to the public and it will most likely be a waste of the shop's time and energy and the customer's money.
Yes Virginia, that means you should have just listened to this answer and had done:
No!! No!!! No!!! NO!!!!! DO NOT let them do that to you!!!!!!!!!!!!!....et al
Old Aug 22, 2007 | 01:43 AM
  #52
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're building a racing engine that's going to spend it's entire service lifetime of one whole hour spinning at 10,000 RPM before being thrown away or rebuilt, and you want what some would arguably believe is the best possible balance achievable by mere mortal humans, then by all means go ahead and have the shop do whatever they want to modify the flywheel/flexplate along with all the rest of the rotating assembly parts. In this case, the flywheel/flexplate is going to outlive the engine, so you don't care.
If you're not building that engine, and you want to drive a car that you can drive on the street for as long as you like without having to pull and rebuild the entire engine just to change the flywheel/flexplate, then use an off-the-shelf flywheel/flexplate that's balanced to the stock specs, whatever the stock spec happens to be for your particular 1 or 2 piece RMS block. Will it be balanced about as well as any engine ever was from the factory? Absolutely. Will it be absolutely, completely, 100% perfectly balanced? Almost certainly not. Will you ever be able to tell? Almost certainly not. If you think you can discern some miniscule vibration, then you could resort to the aforementioned completely unscientific trial-and-error methods proscribed by the service manual to try to make minor corrections to the balance, even though that's not the "best" way to do it.
If you have a 1 piece RMS block, and you buy a flywheel/flexplate that's neutrally balanced, (notice not internally balanced, and not externally balanced. Those terms have absolutely no useful meaning when referring to 1 piece RMS engines), then you will need to have weight added to the flywheel/flexplate to bring it back to the specs of a factory flywheel/flexplate, which is not neutrally balanced.
Old Aug 22, 2007 | 07:48 AM
  #53
Fbody fan 35yrs's Avatar
Car: 91 Z/28
Engine: 5.0
Transmission: T-56 6 speed
Originally Posted by SpitotRs305
sure i will argue with him... i mean god damn this is ridiculous
are you gonna spin this thing to 8500RPM?? NO then quit being stupid about it you have already been told i am right by other posts bolt the damn useless peice on and go.. and why the hell would you send a email? to lingenfelter about your FIDANZA flywheel...
this sounds like more of your sorta like throw some weights on it and drive it around.... then if it vibrates just move them around... yeah thats right out of a service manual...
like stated above... do you really think that GM took the time to individually balance every piece to match a specific set? NO! this is assembly line **** speed is the key..
if the weight is there like you say then it is ready to run...
and the "rough balance" statement was actually on the CENTERFORCE website refering to CENTERFORCE pieces
and you are telling me that lingenfelter isn't sure cant give you 100% definitive answers on a SBC...
what is this bull about internal in the front external in the rear... how does that make sense i mean think about it... the flywheel is intended to have a specific amount of weight in a specific position that is it...DONE it does NOT NEED TO BE BALANCED...
and if you really need your hand held and really need to make up a bunch of bull **** to oh i don't know seem smarter than some... then your are "less than"
As much fun as this is, I'm growing weary. Adults just agree to disagree, shake hands and move on. Name calling, and sticking your tounge out is for kids. Have a great day!
Old Aug 22, 2007 | 08:46 AM
  #54
Car: 91 Z/28
Engine: 5.0
In review
                  PRICELESS!
                  Old Aug 22, 2007 | 08:48 AM
                    #55
                  dennisbernal91z's Avatar
                  Car: Building LS3, T56 Z28
                  Engine: LS3
                  Axle/Gears: Moser/ 4.11
                  Wow, I acctually just read this entire thread.
                  I bought a motor last year, it was internally balanced. i bought an ATI damper for an internaly balanced motor, then I found a flywheel that came with a T-56. The fly was made for an internally balanced motor. I bolted it on. almost 2000 miles later and a lot of "FUN" time, and she has no vibrations at all.
                  just get the fly balanced, if you wanna play it safe, buy a new damper that is zero balanced too. Bolt them on and DRIVE.
                  Old Aug 22, 2007 | 11:43 AM
                    #56
                  Guest
                  Guest
                  Posts: n/a
                  According to Centerforce catalog, its a 23.4 in/oz imbalance/counterweighting. They actually sell them this way, ready for use. Weird huh? I dont know what Fidanza's problem is.
                  I dont know why you arent using your head personally. As I mentioned before, go anywhere and ask for a FLEXPLATE. They'll look it up and pull exactly the same item off the shelf every time. As always, you install it on the car, and drive it away. There's no questions, no rocket science, no screwing in weights, its ready to go and with a 1 piece rear main it has a weight attached. You dont cut this weight, adjust it, or anything. You run it. Its because there IS a specification for how much weight there needs to be and where. Its no different than a flywheel in that regard. The imbalance is related to the crank, not that its a stick or auto.
                  And if you think an imbalanced flywheel cant be balanced alone.... I dont know what to tell you. Every single small block Ford is like that, and its never been a problem. And they have 2 different weights just like Chevy its just that both of them are imbalanced rather than 1 being zero/neutral. Here's some more info for you since you've never dealt with balancing engine parts before, apparently...
                  http://www.goodson.com/technical_sup..._balancing.php
                  You can use the Drill Calculator with the Flexplate and Damper data to quickly convert a flywheel from a neutral to an external balance. You could also correct many crankshaft, flywheel and balancer mismatches without engine removal or disassembly. Simply select the desired radius and drill size, then the drill calculator converts the weight error to drill depths for the selected number of holes to make the correction. For example, you could convert an early 302 Ford flywheel to a late model or vice versa.
                  Oh and I love that manual
                  Continue until vibration is reduced.
                  Note it doesnt say eliminated. I guess if you want to tear up your main bearings by playing guessing games with weights, be my guest. Not my engine.
                  Old Aug 22, 2007 | 05:49 PM
                    #57
                  Car: 91 Z/28
                  Engine: 5.0
                  I called the tech dept at Centerforce, and got voice mail. I asked them to give me a call back.
                  I looked at their flywheel info, and I'm quite sure the 23.4 imbalance is how the Fidanza is built too.
                  This is cut and pasted from the bottom of the flywheel page........
                  1 - All Centerforce counter balanced flywheels are rough balanced. We do not recommend aluminum flywheels for street applications. SOME ALUMINUM FLYWHEELS ARE SPECIAL ORDER ITEMS, PLEASE CALL FOR AVAILABILITY
                  No way would I call "rough balanced" a "ready to use product".
                  I ask you this.... isn't comparing a solid metal flywheel with a solid metal pressure plate attached, and a flex plate with a fluid filled viscous clutch bolted to it a little like comparing apples and oranges? I could see the fluid dampening property's of the torque converter canceling small imbalances that might exist. On the other had with a light weight flywheel the lack of mass could exacerbate the condition.
                  Something is prompting these companies to say things like "must be balanced to match existing flywheel" "rough balanced" and "not recommended for street use" I have a feeling that last one is for people who just want to slap a rough balanced flywheel on and have it run smooth as silk with they're poly motor and trans mounts.
                  I will follow up with Center Force, and ask them why they only rough balanced. Thanks for the input Madmax.
                  Centerforce just called me back while I was sitting here. He gave me the figure 75% of people bolt and go, and "usually" the factory tolerance is close enough to not cause a problem. 25% of the time people go ahead and have them checked with the crank to be sure. He did say if your car didn't vibrate before to match your new one to the old one to be sure. Basically no guarantee's but your odds are good that there won't be a problem.
                  Old Aug 22, 2007 | 06:16 PM
                    #58
                  Apeiron's Avatar
                  Engine: 383 Carb
                  Transmission: 4L60
                  The torque converter doesn't really have any fluid balancing properties since it's completely filled with fluid with no air space. It's true that the flexplate and converter together have much more mass than a flywheel alone, but the converter itself is perfectly neutrally balanced so it may as well not exist as far as balancing is concerned.
                  If I had to guess why they're only selling "rough balanced" flywheels, it's probably to reduce manufacturing cost. It's easier to produce a line of neutrally balanced flywheels than a number of non-neutrally balanced ones. For that matter though, stock engines can be considered only rough balanced, since they don't all get individual treatment.
                  Old Aug 22, 2007 | 06:21 PM
                    #59
                  Red Devil's Avatar
                  Car: Tree Huggers
                  Engine: Do Not
                  See:
                  Liability; Vicarious Liability; Affermative Defense... and probably a half dozen more, but that should give you your answer right there. If you are expecting to get this direct of an answer from a manufacturer, well, don't.
                  Try: http://www.lectlaw.com
                  And the dampening is done by the torsional damper, which you do have (one hopes) not the torque converter.
                  Old Aug 22, 2007 | 07:45 PM
                    #60
                  Car: 91 Z/28
                  Engine: 5.0
                  I have to say Centerforce was much more willing to stick their neck out on the phone than Findanza was. I like their odds better than the 50/50 I was giving it. It's food for thought.
                  Cam-aro
                  Camaros Wanted
                  Nov 12, 2015 03:35 PM
                  Vincent135
                  Sep 28, 2015 10:50 PM
                  mfp189
                  Sep 27, 2015 09:25 AM
                  monte87cortez
                  Sep 26, 2015 08:10 PM
                  italiano67
                  Sep 22, 2015 08:42 AM
