installing rocker arm stud
Old Aug 4, 2007 | 02:40 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok this will probably be a stupid question but when installing the studs the washers go on the bottom side right? between the nut on the stud and the guideplate? also i have 34 washers total so 17 per head. why is there 17? that seems odd to me.
Old Aug 4, 2007 | 07:28 AM
Re: installing rocker arm stud
Guide plates usually don't use washers; the stud has a little shoulder that fits into a chamfer in the hole of the guide plate to locate it.
Oddly enough, there are 17 head bolts per head; 34 total. Sounds like you left the head bolt washers off?
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Cameeeero
Aug 20, 2015 03:06 AM
