Custom Power Steering Bracket?
Old Aug 4, 2007 | 08:54 AM
mouthforcombat's Avatar
Car: '86 Iroc Z
I have recently installed hedman headers on my Iroc. Problem with that is the stock power steering bracket will not fit now. I swear I have heard people talk about custom brackets that get made for headers. Anyone have any info for me? Thank you in advance.
Old Aug 4, 2007 | 11:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Cut off one leg. Just use one bolt mount to the header. Use a spacer so the header flange and spacer will be the same thickness as the stock manifold, and a stock manifold bolt.
Old Aug 6, 2007 | 04:19 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Re: Custom Power Steering Bracket?
I used a set of March brackets on my car that work perfectly and look good to boot. Check Summit or Jegs for them. I also use Hedman headers as well.
Old Aug 6, 2007 | 04:39 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
I had a 305 H Carb which had the 3-belt setup. The PS bracket had a mount that bent around to the LF header bolt. The stock used a long stud with an extra stud on top fo a nut to tighten down the bracket to. I simply went and got a thick 2" steel tube from Lowes and cut it to the deired length to take up the space. Instant spacer! That was Headman headers too. Ive since got SLP 30005C headers and they already have it welded to them.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
