Distributer cap bolt size?
Old Aug 7, 2007 | 08:37 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Anyone know offhand what the size and thread are of the distributer cap bolts? I need to helicoil my base.
Old Aug 7, 2007 | 08:50 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Distributer cap bolt size?
No. But why don't you just use a larger screw? The base is aluminum so you should be able to force a re-thread.
Old Aug 7, 2007 | 09:50 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Id rather helicoil so I dont ahve to mod future replacement caps to fit teh base.
Old Aug 7, 2007 | 09:55 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Knowing GM it's probably an off-the-wall size like 4.5mm 28pitch. Just a guess. I don't have a tap and die set.
Old Aug 7, 2007 | 02:30 PM
Cflick's Avatar
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
It appears to be a #6 wall socket thread, but I couldn't find a screw laying around to test.
Stripped mine, but there's a relatively easy fix.
Take a pair of fairly good size vice grips, and crush the aluminum plate at the hole.
Thread the stock screw back in. DON'T over tighten it ! It won't take much to strip it again if you do. ( don't ask ) Next time ( yeah, right ) I strip mine, I'm gonna look for some of that aluminum solder, solder up the hole, and start over.
Old Aug 7, 2007 | 07:49 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Theyre finer then a #6-32, but larger then a #4-40. Probably some odd metric size. Im tempted to buy a slew of small bolts from a specialty house to see if I can match it to something
Old Aug 7, 2007 | 08:04 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I guess if I had to take a guess, Id say its either #6-40 or 3mmx.5.
Infested
May 22, 2018 11:56 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
Brcharrelson
Aug 26, 2015 07:47 PM
knight72
Aug 10, 2015 09:32 PM
