Please say yes
Old Aug 8, 2007 | 02:58 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Please say yes
I broke two thermostat housings on my TPI. They were both aluminum. THe replacment one I bought from the store is an iron one. It worked great.
I am a bit scared running it because its not aluminum. I am not sure if I should be worried or not??
On one hand I like it because it worked great. I broke TWO aluminum (stock) housings but it was because I did not clean the surface well. Now its spanking clean with an iron housing.
Do you think this will pose a problem, or will it be alright.
(I am seriously thinking that it'll be alright, but i need that piece of mind).
Old Aug 8, 2007 | 03:38 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Please say yes
how did you break the other housings??
the iron should be fine.. dont see why it wouldnt or how you broke 2 housings.. just make sure you dont run straight water(like the .001% of people that do).. painting the outside would help with rust too.. dont forget, good prep=good paint..
Old Aug 8, 2007 | 10:27 AM
Re: Please say yes
I torqued them down to about 22 and anything over that cracked the side. The problem was that I did not clear the little recess area where the thermostat goes. so Basically the thermostat was out a bit to high and it would put enough pressure on the aluminum housing to where it would snap. I got that cleaned up and now it bolted on perfectly.
Old Aug 8, 2007 | 12:33 PM
5678TA's Avatar
Car: 1984 Trans Am
Re: Please say yes
well in that case, you should be fine..
