please help should i buy it?
Old Aug 8, 2007 | 05:53 PM
dirt_kx's Avatar
i have a chance to buy a 88 z28 it has a 350 with a 6 speed tranny but 2nd gear is gone it will not move at all in that gear the engine runs but needs a little work also it has rear disc and t top is it worth $600 with the tranny problem is it expensive to fix thanks for any help
Old Aug 8, 2007 | 06:06 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: please help should i buy it?
If the rest of the car is in decent shape and the engine has no major issues, the price sounds good. You can check on this site for used trannys, use the search option on the top of the page.
Old Aug 8, 2007 | 06:20 PM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Worst case a tranny rebuild with a trans cooler will run you $1200- worst case.
Old Aug 8, 2007 | 06:31 PM
dirt_kx's Avatar
the tranny shop told me it would be atleast a 1000 but probly more
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
