spark plugs
Old Aug 9, 2007 | 11:52 PM
Black89TransAm's Avatar
Car: 89 Trans Am, 84 Firebird
Engine: 305 TBI
Transmission: 700 R4
spark plugs
what kind of spark plugs do you guys suggest i should get for my car 89 TBI trans am
Old Aug 10, 2007 | 12:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Standard copper core resistor plugs of most any brand, whatever the parts store application tells you, will run as good as any other type. They just don't make that much difference, one from another.
Some may last a little longer, but you rarely get more by paying more.
Old Aug 10, 2007 | 12:11 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: spark plugs
Word is, (and I might just be spreading misinformation) that anything above a platinum plug in our cars doesn't work as well, as the Platinum +2 and +4's need a higher spark voltage (like those from distributor less ignition) or an aftermarket HEI box, if you're running the stock electrical, the NGK V-Power 6630 is an awesome plug at an awesome price. I think I bought mine at $1.99 a plug.
Old Aug 10, 2007 | 01:37 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: spark plugs
i only use $1.59 AC Delco resistor plugs. they're honestly the best for these cars.
Old Aug 10, 2007 | 09:03 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: spark plugs
I agree with the AC Delcos.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
