What to run?
Old Aug 11, 2007 | 08:24 AM
mlaudon's Avatar
Car: 89 Camaro Rs
Engine: 355 build up
Transmission: TH350
What to run?
Well i have a 89 rs with the 305 the stock one and i plan on puttting a 350 in and its going to be carbed so my 305 that i have has fuel problems and so im just going to make it carbed with the 305 and the car has no AC or smog pump now and i was wondering if i could run a belt set-up like a 84 that is carbed with each different belt on my 89. hope you guys can give me some help and maybe some help with a fuel set up for it sence i have one in the tank do i have to get a 84 or any carbed tank or can i just by-pass the stock pume any ideas would be great? Thanks.
Old Aug 11, 2007 | 09:22 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: What to run?
That beats my best run-on sentence by a mile!!
You can run the early model setup if you can find the P/S pump, alternator and brackets to put on. You may have to do some wiring to connect to the relocated alternator.
About the fuel system, you can use a bypass regulator and not have to drop the tank.
It is discussed in detail HERE.
You can see the picture of my setup from TPI to carb. The TBI should be similar.
Old Aug 11, 2007 | 10:07 AM
mlaudon's Avatar
Car: 89 Camaro Rs
Transmission: TH350
Re: What to run?
well thanks for the help. Yes im pretty good at the whole run on sentence thing.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
