l69
Old Aug 14, 2007 | 02:51 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
l69
i have a 1984 camaro with the l69.i just replaced my passengers side air injector now my check engine light is on also the car smokes really bad on start up then kinda dies down but never quits the higher you rev it the more it smokes also it seems like im losing tranny fluid but i cant find a leak. i know i need valve seals but could i have some vac lines off or something that would cause the loss of tranny fluid and smoke?? my oil pressure is around 30 at idle and then goes to 60 at higher rpm.also the car idles around 500rpm.
Old Aug 14, 2007 | 03:55 PM
Engine: L69 H.O
Re: l69
Anyone??? i really need to get this figured out
Old Aug 14, 2007 | 04:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Patience, Grasshopper, good things come to those who wait. . .
It's hard to imagine a connection between replacing the passenger side A.I.R. (was this the tube manifold, or the check valve) and a smoking engine. SES light could be from something that was knocked off during the process.
Retrieve the trouble code(s) and at least start from there. I can't think of any trouble code that would include smoke, though.
Old Aug 14, 2007 | 05:12 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: l69
used to have a LU-5 that did this, it's problem was sludge buildup in the heads and it blocked the oil from returning to the pan .... check the heads for sludge
Old Aug 14, 2007 | 05:54 PM
Engine: L69 H.O
Re: l69
do you mean slude on the rocker arms and valve springs because my stock ones look almost brand new also i have no way of checking my codes and i just went a started it for a minute and my check engine light was off just every once in a while it will randomly come on and stay on then just go off all of the sudden. thanks for all the replys.
Old Aug 14, 2007 | 08:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: l69
Use a paperclip to pull the codes, it's pretty high tech, matches the '80s car well.
Do a search for more info on the paperclip trick.
Old Aug 16, 2007 | 03:01 PM
Engine: L69 H.O
Re: l69
Anyone else think they can help.
Chuck84TA
Jul 15, 2016 09:05 PM
PurelyPMD
May 5, 2016 04:57 PM
Night rider327
Oct 13, 2015 01:47 AM
leighgrils
Oct 9, 2015 09:38 PM
clemsparks
Carburetors
Nov 10, 2001 12:13 AM
