i doubt I'll make it to the track more than 2 times a year but...
Old Aug 16, 2007 | 01:59 PM
i_love_thirdgen's Avatar
Car: 92 camaro,99 s10
Should I get performance heads anyways?
My setup... 350 4 bolt mains, Xe268H Comp cam, Edelbrock Performer RPM gasket matched, Holley 600cfm VS carb, this is all on a Jasper reman engine with "made in Mexico" heads and about 14,000 miles on that setup
Also running a 700 r4 and 3.73 gears out of a posi iroc rear (in my 92 rs,originally a v6 car)
I'm still going to buy the correct springs for the cam, a K&n Xstream air filter, and a 125 shot of laughing gas
But any input would be awesomee!!! P.S. I'm shooting for (high?) 12's, Thanks!
Old Aug 16, 2007 | 02:05 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: i doubt I'll make it to the track more than 2 times a year but...
Why not? If you can afford them, they would compliment what you've already got. The carb seems on the small side for a mild cam 350. You're probably gonna approach them limits of what the carb can deliver if you get a decent breathing set of heads on there. I would think you'll be into the 12's on a 125 shot no problem, stickie tires would really compliment everything else, especially on the spray. Gonna be tough to hook street tires on a 3.73 rear, 3.06 first gear, and spray.
Old Aug 16, 2007 | 02:09 PM
any ideas on which heads to run?? Moneys tight but i can $ave... More than likely after the heads and driving it for a while I'll get a 750dp. Thanks man.
Old Aug 17, 2007 | 11:32 PM
thrilla135's Avatar
Car: 1987 trans am
Engine: 406
Transmission: th:400
Axle/Gears: 4:88
FOR YOUR setup i would go with some world s/r torquers...theyre cheap for aftermarket..and great street heads...with the 170 runners and 2.02's they make good torque..perfect for a street car
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
rithsleeper
Aug 11, 2015 07:55 AM
