oil pressure
Old Aug 16, 2007 | 05:05 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
oil pressure
1984 camaro with the 5.0 HO. i get a big cloud of smoke when i start the car and the it kind dies down a bit after a few seconds it has been doing this for a while. and now my oil pressure has dropped it used to be almost 60 at idle while warming up now it sits around 30 and a couple times when i reved it up it dropped just a hair under 30 for some reason anyone have a clue as to what may be wrong?
Old Aug 16, 2007 | 05:12 PM
rustbird77's Avatar
Re: oil pressure
The first step seems to be to check the sender, and make sure it isnt bad. Try swapping to a new one. If there is still a problem, hook up a mechanical guage to see your actual pressure.
Old Aug 16, 2007 | 05:19 PM
Engine: L69 H.O
Re: oil pressure
Thanks for the info i will try that.also if i just turn the key when i restart it after shutting it off it runs like crap! but as soon as i tap the gas it runs good again?
Old Aug 17, 2007 | 04:11 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: oil pressure
Your cloud is most likely valve seals. Could also be valve guides but always start with the cheap stuff.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
