car idle problems please help
Old Aug 19, 2007 | 08:56 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
my 91 z28 will hold an idle at 1500for like 5 min then drop to 500 and idle really rough also when I try to give it any throttle it acts like it does not get any fuel I had a gauge on it and read 40-43 psi then dropped to 20-25 psi when it died could this be the fpr?? also it has a new tps on it
thanks,,steve
Old Aug 22, 2007 | 04:57 PM
bigdaddy89's Avatar
Re: car idle problems please help
im having the same problem with my 91 camaro.... but mine will idle at about 750 rpm and will die if u give it any gass but .. heres the thing , when i unplugg the alternator it will idle at about 1500 rpm and i can rev it up to almost 4000 rpms but when i put it in gear it has no power ... if u find anything out will you please let me know?
Old Aug 22, 2007 | 08:26 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
I have a 91 shop manuale and from what I can get out of that it might be the fpr I cant get one till the weekend but if it helps mine I will let you know
Old Aug 23, 2007 | 12:33 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Maybe the fuel pump if the FPR checks out.
Old Aug 23, 2007 | 04:16 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
newpump was put in back in feb
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
