How to tell which engine?
I just got my first third Gen. It's a 1988 Trans Am GTA. It has V-8, automatic and t-tops. There are no stickers under the hood telling which engine. Does the VIN tell me whether it's a 5.0 or 5.7?
Thanks,
Dale
Thanks,
Dale
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How to tell which engine?
The VIN will tell you what it was from the factory, the casting numbers will tell you what it is now.
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
GTA's came with the 5.7 unless you ordered the 5sp then you got the 5.0. if your car is still stock you should have a 350 under the hood.
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey dacecil - the info regarding the 8th digit in the VIN is correct.
There should be a sticker / decal under the hood that tells the
story also - but those over time may disappear. For the record,
there are '88 GTA'S running around with 305's and 700R4 auto-
matics from the factory.
A quick way also to tell is, if you can see down by where the engine/ trans bolt togather on the driver side, if its a 305 it'll have a 5.0L stamped in the block. If it doesn't you have a 350.
Car: 1988 Trans Am GTA
Engine: 350 4BBL
1990 Firebird history: "L98 1990 cars no longer offered with T-Tops due to supposed torque limitations of the unibody construction, although all L98 cars before were available with T-Tops successfully"
84z96L31vortec
Aug 20, 2017 12:16 AM
