tracing knock
Old Aug 24, 2007 | 04:27 PM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
tracing knock
i have been having some problems with my car pulling the timing shortly after timing it. i got a sacanner and saw the car is sensing knock, but dont hear anything out of the ordinary. i do have some pretty bad exhaust leaks at the hedders (bolts keep backing out) and my y-pipe hits the subframe connector, however i have a piece of rubber hose in between that and it wasnt a problem long ago when i had the car tuned
i have pulled one valve cover off just to check that nothing was out of place. all rockers seemed tight enough, no pushrods out of place, and the rockers couldnt be hitting the valve covers because they are 1.5's with tall valve covers, and i never had that problem before.
does anyone have any ideas of things i could check? i have no idea how to tell what the knock sensor is picking up
more info:
timing starts getting pulled around 3000 rpm
92 camaro speed density
350 gmpp crate motor with tune
ran perfect for a few months after a tune, then had problems and couldnt drive it hard, therefore didnt know about the timing being pulled
have timed it at least twice and tiing is pulled the next day, however runs great on trial runs after setting timing
any help would be appreciated, maybe i can learn something here too
RedLeader289
May 28, 2019 01:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
