Back to cruise control
Old Aug 24, 2007 | 02:36 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Hey guys, I guess I have to start from the beginning. Sometime ago I had to replace my whole steering column (don't want to elaborate).
Anyway, after I replaced it was when my dumb a$s realized it did not have the cruise switch on it unlike my original one. The cruise module is still under the hood and stuff but I'm wondering if I can rewire it and put in a switch or do I have to get one of those old aftermarket type cruise control kits? Any decent help will be appreciated.
Old Aug 24, 2007 | 03:23 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Back to cruise control
if you just changed the column , and left every thing else intact . then all you need is signal arm assy. with cruise sw. . cheap and lots on ebay .
Old Aug 24, 2007 | 03:39 PM
Guro 305's Avatar
Axle/Gears: Stock
Yup, everything is intact but wouldn't I have to take apart the steering column to get at it?
Old Aug 24, 2007 | 04:30 PM
UNCLE TOM's Avatar
i dont think so . according to my service manual [ the real deal , from chevy ] there is a wireing protector , sort of a tunnel or tube on the lt. side of the column . when you go to replace , make sure lever is in center position , remove lever [ should pull straight out ] thread a straight piece of semi-straight wire up through the tunnel or tube . you should be able to see it in the hole lever came out of . hook that wire to new cruise wire and pull it down column . plug in , re-install lever and play .
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
