Stock Tachometer
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Stock Tachometer
How far off is the stock tach usually? Read fast or slow? J/C.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Stock Tachometer
I'm pretty sure mine is fairly accurate. Maybe i'll hook up a spare I have laying around in parallel to find out...
I'm pretty sure at idle it's accurate, and at ~3000RPM cruise...
Most people say their tachs read high though, something in the range of +/-10%
They seem to fail by reading higher..
All of the ones I have read high. The one in my car is the least high, at about 3-4% (or was when I put it in at least..) I have one that's 100% high (reads twice actual RPM).
It's meaningless to talk about "xxx RPM off". That's equivalent to having the pointer installed wrongly on the movement. They don't go bad that way. Rather, they read a PERCENTAGE off. So it might be 100 RPM at idle, 250 RPM at cruise, etc.
ambainb
Apr 25, 2016 09:21 PM
Genopsyde
Oct 7, 2015 08:35 PM
