Mini starter problems
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
I just finished my swap 82 ta with a 375Hp 350. my problem is I've gone through 2 staggard bolt pattern mini starters. they claim to start 18-1 compression and are used in some race applications. my compression is about 10-1. no matter what shims I put in (i've put in none and i've put in alot, and everything in between) but I have the same problem, it either retracts after only engaging for a second or two, or makes an ungodly grinding noise. I have been able to start it now and then but it seems to get worse and worse as I crank, has anyone had these problems? timing is fine at about 10* BTDC. thanks
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
Re: Mini starter problems
yes I did verify 168 tooth flywheel and the block was remaned so I did not tap it, it's possible they did.
mhatfield 14
Oct 24, 2015 07:48 AM
Dialed_In
Aug 20, 2015 01:45 PM
