Engine Light is On?
Old Sep 3, 2007 | 02:16 PM
Soenneker's Avatar
Car: 85 Firebird
Engine: V6 2.8L
Engine Light is On?
a
Old Sep 3, 2007 | 08:50 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: Engine Light is On?
try this link to get your real codes.
https://www.thirdgen.org/forums/tech...ine-light.html
attachment is the connector.
Old Sep 3, 2007 | 08:53 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Oh, find the coolant leak. don't pour crap in your radiator to plug leaks.
btw. do you have a working speedometer?
Old Sep 3, 2007 | 09:03 PM
Soenneker's Avatar
Car: 85 Firebird
Engine: V6 2.8L
Yes, the speedometer works just fine, except for, of course, when accelerating at speeds of around 0-20 the needle jumps around between 0 and 20. Then it settles down when speeds reach around 30, of which it stays steady. Is that normal?
Old Sep 3, 2007 | 09:41 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Could be the EGR if it comes on while cruising for extended periods of time. Check the codes and post back!
Old Sep 4, 2007 | 11:26 AM
Soenneker's Avatar
Car: 85 Firebird
Engine: V6 2.8L
b
Old Sep 4, 2007 | 09:59 PM
Soenneker's Avatar
Car: 85 Firebird
Engine: V6 2.8L
c
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
